thyandrecardoso
Bug exporting terrain as image: name and path
Discussion created by thyandrecardoso on Nov 27, 2011
Latest reply on Dec 7, 2011 by MBuehler-esristaff
In linux, if you try to export a select terrain as an image, and choose a directory to which to export to through the "browse" button available in the export dialog, the image never gets exported to the correct place. It gets exported to the directory "beneath" the chosen one. For example, if you choose "/home/user/Desktop", the image gets exported to "home/user", with incorrect naming!
I think the exported is expecting an extra "/" at the end of the path given by the directory picker ("browse" button)...
If you do the same, using the directory the "browse" button, but insert the extra "/" at the end of the path afterwards, then the image is created in the right place, but still gets a wrong name.
Btw, this was also happening on the 2010.3 version of CE.
Using Ubuntu Linux 11.01, Unity, 64 bit, CityEngine 2011 64 bit
André
Outcomes
