Set extent to "Same as Display"
724
11-24-2011 06:17 AM
HenkZwols
I made a model with 'extent' as modelparameter.
When a user runs this model he has to choose "Same as Display" most of the time.
Is there a way to invoke this choice by code so user just has to push the OK-button?
Greeting, Henk
HenkZwols
I thought it would be possible by code in Tool Validation:
class ToolValidator:
  """Class for validating a tool's parameter values and controlling
  the behavior of the tool's dialog."""
  def __init__(self):
    """Setup arcpy and the list of tool parameters."""
    import arcpy
    self.params = arcpy.GetParameterInfo()
  def initializeParameters(self):
    """Refine the properties of a tool's parameters.  This method is
    called when the tool is opened."""
    for param in self.params:
        if param.name == 'Extent':
           param.ExtentRule = "Same as Display"
           break
But that doesn't seem to work.
Anyone an idea?
Greeting, Henk
