menglish
Model Builder Environments and QA phases:
Discussion created by menglish on Nov 21, 2011
Latest reply on Nov 21, 2011 by withershin
Hello:
I have generated some fairly extensive models (17 geoprocesses) that appear to function efficiently.  If I want to use the model for a different dataset, I have to go in to each process and change the input/output location and file name.  Is there a method to change all the outputs/inputs or 'environment' to a specific database geodatabase at once?  Thanks in advance.
I also am required to QA a process in the middle of one of my models.  SHould I just break the model where QA is required, or is there a sharper way to allow this interaction in the design?  Thanks again...
Outcomes
