I am using ARCGIS 10.0. I am trying to populate a field through CalculateField.
The approach I am trying now, is to build a stack-class to contain the values. Then I can use a method from the stack-class as the function that goes into CalculateField. My command looks like this:
[INDENT][/INDENT]gp.CalculateField_management(tmpcopy, 'temp', 'AsStack.GetVal())', 'PYTHON')
The resulting error message is:
[INDENT][/INDENT]ExecuteError: ERROR 000539: Error running expression: AsStack.GetVal()) <type 'exceptions.SyntaxError'>: unexpected EOF while parsing (<string>, line 1)
Failed to execute (CalculateField).
I have confirmed that AsStack.GetVal() gives the correct number of real-values between zero and one.
I have found a couple of similar commands that do work:
[INDENT]gp.CalculateField_management(tmpcopy, "temp", 'numpy.random.rand()', "PYTHON")
[/INDENT]gp.CalculateField_management(tmpcopy, "temp", 'AsStack.nval', "PYTHON") (nval is just an integer value)
I am running out of things to try. The calculations I am using do require an external library (rpy2). I might be able to avoid the stack-class - but eventually I do think I will need to give CalculateField_managemen a method from a class as the python-expression.
Does anybody have a suggestion for what I should try next?
Wayne Hajas
