Rebuild a raster's pyramid?
223
11-17-2011 08:54 AM
PatrickYoung1
I've been having a problem getting the pyramid layers of a raster that has been modified to rebuild.  The raster has had some pixels that have been changed, but I can't get the pyramids to work.
The following piece of code throws an exception along the lines of "Failed to build pyramid" when I hit the DeletePyramid command:
/* Convert the ILayer to an IRasterLayer. Note that ApplicationState.CurrentExtractionRasterLayer is an ILayer in my application. */
IRasterLayer irl = ApplicationState.CurrentExtractionRasterLayer as IRasterLayer;
// Rebuild the pyramid layers.
IRasterPyramid3 irp3 = (irl.Raster as IRaster2).RasterDataset as IRasterPyramid3;
irp3.DeletePyramid(); // Exception thrown here!
If I instead call
irp3.Create();
in place of DeletePyramid(), no exception is thrown, but only the bottom layer of the pyramid is correct!  Any ideas on where I've gone wrong?  I thought that it could be the case that Arc is somehow not allowing itself to overwrite the .ovr file it created when the layer is loaded, but I really have no idea.
Thanks!
-Patrick
