Hi,To set labels for graphic features you can create your own custom MarkerSymbols (or LineSymbols/FillSymbols) by using a ControlTemplate. The following example defines a symbol in XAML in the Grid.Resources section then in code it creates 10 random points and assigns the custom symbol to them, labelling them with an attribute called "NAME".XAML:<Window x:Class="GraphicLabel.MainWindow"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
Title="MainWindow" Height="350" Width="525">
<Grid x:Name="LayoutRoot">
<Grid.Resources>
<esri:MarkerSymbol x:Key="labelSymbol" OffsetX="6" OffsetY="6">
<esri:MarkerSymbol.ControlTemplate>
<ControlTemplate>
<Grid>
<!--Marker-->
<Ellipse Width="12" Height="12" Fill="Red" HorizontalAlignment="Left" VerticalAlignment="Top" />
<!--Label-->
<Grid Margin="8,8,0,0" HorizontalAlignment="Left" VerticalAlignment="Top" IsHitTestVisible="False">
<!--Text halo using a white blurred text-->
<TextBlock Foreground="White" Text="{Binding Attributes[NAME]}" >
<TextBlock.Effect>
<BlurEffect Radius="5" />
</TextBlock.Effect>
</TextBlock>
<!--Text-->
<TextBlock Foreground="Black" Text="{Binding Attributes[NAME]}" />
</Grid>
</Grid>
</ControlTemplate>
</esri:MarkerSymbol.ControlTemplate>
</esri:MarkerSymbol>
</Grid.Resources>
<esri:Map x:Name="_mapControl" Background="Gray" WrapAround="True">
<esri:ArcGISTiledMapServiceLayer ID="arcGISTiledMapServiceLayer"
Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer" />
<esri:GraphicsLayer ID="graphicsLayer"/>
</esri:Map>
</Grid>
</Window>
CODE:using System.Windows;
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Symbols;
using ESRI.ArcGIS.Client.Geometry;
using System;
namespace GraphicLabel
public partial class MainWindow : Window
public MainWindow()
InitializeComponent();
Random random = new Random();
GraphicsLayer graphicsLayer = _mapControl.Layers["graphicsLayer"] as GraphicsLayer;
for(int i = 0; i <=10 ; i++)
Graphic graphic = new Graphic()
Geometry = new MapPoint(random.Next(0,10000000),random.Next(0,10000000)),
Symbol = LayoutRoot.Resources["labelSymbol"] as MarkerSymbol,
graphic.Attributes.Add("NAME",string.Format("Point {0}", i.ToString()));
graphicsLayer.Graphics.Add(graphic);
CheersMike
