jmillanq
Running Python without ArcGis interface
Discussion created by jmillanq on Nov 3, 2011
Latest reply on Nov 9, 2011 by stacyrendall
Hi, I'm running a loop over network analysis (270x56 matrix). The loop is working much better now but I would like to know if there is a way to run a python code over ArcGis with out open the ArcMap interface.
What is more, I cannot run my code directly from the python shell and I always have to manually upload the layers that i need as inputs, load my code in the ArcGis python interface and the run it. Is it possible to upload and use layers using a python code?
Thanks in advance. Below you find a copy of my python code.
Best
J
#   FIND THE ROUTES AND EXPORT
#      Description:
#           This script aims to find and save the best route from each starting
#           point x to each destination point y, over the network of roads.
#           to do this I follow these steps
#               1. Create master layer, input layers and the output base
#               2. loop over origin x and destination y:
#                   a. Create the stops
#                   b. Solve the route
#                   c. Select roads and municipalities and save them in output layers
#                   d. Clean master layers
#   VERY IMPORTANT ->   REMEMBER TO THE FILES IN THE WORKING AND OUTPUT FOLDERS
# PREABULE
# Declare: Folder Paths
path = "C:\Users\uctpjam\AnalysisDDRoutes111020\\"
#           The path is the key local to change in order to run the same program over
#           different folders.
pathWorking = path + "ToWork\\"
pathOutput = path + "Output\\"
# Declare: Network Analysis Locals
MRoute = "MasterRoute" # I can solve over one Make a route layer
inputLyr = MRoute + "/Routes"
NetLines = "vias_unificado"
Active_Net = "Roads/vias_unificado_ND" # Active network
hrch = "USE_HIERARCHY"  # Declare Hierarchy
cost = "Length" # Cost variable#
op1 = "USE_INPUT_ORDER"
op2 = "PRESERVE_BOTH"
op3 = "NO_TIMEWINDOWS"
op4 = "ALLOW_UTURNS"
op5 = "TRUE_LINES_WITH_MEASURES"
# Declare: Program local variables
Org = "orgRoads"
Dest = "destRoads"
Stp = Org + ";" + Dest
mStop = "Stops_Master"
mpios = "wlMunicipios"
baseMpio = "routesMnpAll"
baseLine = "routesLineAll"
# Call the packages
import arcpy, os    # Argis
from arcpy import env # Import environments
env.workspace = path
# 1. SET UP MAIN AND MASTER LAYERS
# Check out any necessary licenses
arcpy.CheckOutExtension("Network")
# Process: Make Route Layer
arcpy.MakeRouteLayer_na(Active_Net, MRoute, cost, op1, op2, op3, "", op4, "",hrch, "", op5, "")
# Process: Master Stop Layer
arcpy.CreateFeatureclass_management(pathWorking,mStop,"POINT",Org)
# Process: Municipalities Output
#       Note: I'm having problems with the field names. What I'm doing is to create 2
#               copies of the "Municipios" Layer, one empty one as master layer
#               and one full as input layer.
arcpy.CreateFeatureclass_management(pathOutput,baseMpio,"POLYGON",mpios) # Master layer
# Process: Output Road Layer
arcpy.CreateFeatureclass_management(pathOutput,baseLine,"POLYLINE",NetLines) # Base
# Process: Add Field with the route name
LYR = [baseMpio, baseLine, NetLines, mpios]
for i in LYR:
    arcpy.DeleteField_management(i,"routeCode")
    arcpy.AddField_management(i,"routeCode","TEXT","#","#","#","#","NULLABLE","NON_REQUIRED","#")
# Process: Expression (core) to get the route layer
expression = "categoria(!routeCode!)"
# 2. FIND THE ROUTES - LOOP OVER ORIGIN/DESTINATIONS
for x in range(0,270):
    for y in range(0,56):
        # Declare Local Variables
        selectOrg ="FID=" + str(x)
        selectDest ="FID=" + str(y)
        outRuta = "Route_"+str(x)+"_"+str(y)
        rutaVar = "'" + outRuta + "'"
        vLocal = "selecOrg, selectDest, outRuta, rutaVar"
        # Process: Select Origin and Destination
        arcpy.SelectLayerByAttribute_management(Org, "NEW_SELECTION", selectOrg)
        arcpy.SelectLayerByAttribute_management(Dest, "NEW_SELECTION", selectDest)
        # Process: Append the stops to Stop Master
        arcpy.Append_management(Stp, mStop)
        # Process: Add stops
        arcpy.AddLocations_na(MRoute, "Stops", mStop, "Name Name #", "10000 Meters","","","","CLEAR")
        # Process: Define the expression to get the route code
        codeblock = """def categoria(routeCode):
            if routeCode == ' ':
                return outRuta"""
        try:
            # Process: Solve
            arcpy.Solve_na(MRoute, "SKIP", "TERMINATE")
            # Process: Select by location and create new layer with the municipalities
            arcpy.SelectLayerByLocation_management(mpios,"INTERSECT",inputLyr,"#","NEW_SELECTION")
            arcpy.Append_management(mpios, baseMpio)
            # Process: Select by location and create new layer with the roads
            arcpy.SelectLayerByLocation_management(NetLines,"INTERSECT",inputLyr,"#","NEW_SELECTION")
            arcpy.Append_management(NetLines, baseLine)
            # Process: Route code
            arcpy.CalculateField_management(baseMpio,"routeCode",expression,"PYTHON_9.3",codeblock)
            arcpy.CalculateField_management(baseLine,"routeCode",expression,"PYTHON_9.3",codeblock)
        except:
            print "Error ->  " + outRuta +" doesn't exist"
        # Process: Clear Master Layers
        arcpy.DeleteFeatures_management(mStop)
        del vLocal
        del codeblock
Outcomes
