When I instantiate an AGSMapView like this:AGSMapView *mapview = [[AGSMapView alloc] init];
later calling "setFrame" like this:[_mapView setFrame:CGRectMake(0, 0, self.view.frame.size.width, self.view.frame.size.height - 325)];
produces the following error, when I try to interact with the map object (e.g. autoPan = YES, zoom in/out, or manually pan the map) after I make the setFrame call:Terminating app due to uncaught exception 'CALayerInvalidGeometry', reason: 'CALayer position contains NaN: [nan nan]'
Instantiating the AGSMapView and setting the frame all at once, on the other hand, produces the correct results:_mapView = [[AGSMapView alloc] initWithFrame:CGRectMake(0, 0, self.view.frame.size.width, self.view.frame.size.height - 325)];
I can work around it; if it is in fact a bug, I thought you would like to know.
