ljvasil
code is not updating cursor grid code value in point shapefile
Discussion created by ljvasil on Oct 29, 2011
Latest reply on Oct 29, 2011 by stacyrendall
Hi all,
I've posted this problem before, but I still haven't resolved the error. I'm writing a cellular automata code that changes the grid_code of a point based on the adjacent neighbor grid_codes. The point file is reclassified into likelihood of conversion. The code runs fine until it hits a point that needs to be converted. I'm using setValue to change the current grid code to the new one. The code and the snapshot of the error are shown below. Thanks for any suggestions...I'm at a loss of why it is not updating.
import sys, string, os, arcpy
arcpy.AddToolbox("C:/Program Files (x86)/ArcGIS/Desktop10.0/ArcToolbox/Toolboxes/Data Management Tools.tbx")
ifc = sys.argv[1]
ily = "Input Layer"
desc = arcpy.Describe(ifc)
arcpy.MakeFeatureLayer_management(ifc,ily, "", "", "")
oid = desc.OIDFieldName
uc = arcpy.UpdateCursor(ifc)
line = uc.next()
for line in uc:
ci = line.getValue(oid)
arcpy.AddMessage("The current FID value is " + str(ci))
fi = line.getValue("GRID_CODE")
arcpy.AddMessage("The current GridCode value is " + str(fi))
sql = oid + " = " + str(ci)
arcpy.SelectLayerByAttribute_management(ily,"NEW_SELECTION",sql)
result = arcpy.SelectLayerByLocation_management(ily, "WITHIN_A_DISTANCE", ily, "45 meters", "NEW_SELECTION")
sc = arcpy.SearchCursor(result)
gridList = []
OIDList = []
for row in sc:
item = row.getValue("GRID_CODE")
id = row.getValue(oid)
OIDList.append(id)
gridList.append(item)
del row
del sc
###This section will iterate through the list and pop the cursor Grid Code out of list depending on its position in the file, i.e. how many neighbors it has.
###It will have either 6 neighbors if the cursor is located along the boundary, or 9 if in the middle of the point file. If less than 6, then there wouldn't
###be enough for a conversion.
if len(OIDList) == 9:
OIDList.pop(4)
gridList.pop(4)
gridList.sort()
LR_Value = gridList[-1]
tie_LR = gridList.count(LR_Value)
Sec_lrValue = gridList[-2]
tie_sec = gridList.count(Sec_lrValue)
Thr_lrValue = gridList[-3]
tie_thr = gridList.count(Thr_lrValue)
Frt_lrValue = gridList[-4]
tie_frt = gridList.count(Frt_lrValue)
Fve_lrValue = gridList[-5]
tie_fve = gridList.count(Fve_lrValue)
###This section reads the largest Grid_Code in list and decides whether to convert cursor cell to another land use.
if tie_LR >= 4 and LR_Value > fi:
ni = LR_Value #Just naming the variable a different name. I tried fi = LR_Value and that didn't work either.
uc.setValue("GRID_CODE",ni) #This is what is giving the error. "No attribture called setValue"
uc.updateRow(line)
###If the largest cell wasn't larger than fi or greater than a count of 4, it keeps going through the list to the second largest, third largest, etc.
elif tie_sec >= 4 and Sec_lrValue > fi:
ni = Sec_lrValue
uc.updateRow(line)
elif tie_thr >= 4 and Thr_lrValue > fi:
ni = Thr_lrValue
uc.updateRow(line)
elif tie_frt >= 4 and Frt_lrValue > fi:
ni = Frt_lrValue
uc.updateRow(line)
elif tie_fve >= 4 and Fve_lrValue > fi:
ni = Fve_lrValue
uc.updateRow(line)
elif len(OIDList) == 6:
OIDList.pop(1)
gridList.pop(1)
gridList.sort()
###This is a duplicate of the condition statement in the loop above this. It's messy and I probably can pull it out of a loop, but I haven't tried it yet.
ni = LR_Value
uc.updateRow(line)
ni = Sec_lrValue
uc.updateRow(line)
ni = Thr_lrValue
uc.updateRow(line)
ni = Frt_lrValue
uc.updateRow(line)
ni = Fve_lrValue
uc.updateRow(line)
else:
arcpy.AddMessage("Not enough points to make conversion.")
#elif len(OIDList) == 4:
#OIDList.pop(0)
#gridList.pop(0)
arcpy.AddMessage(OIDList)
arcpy.AddMessage(gridList)
#arcpy.AddMessage("The large value in list is " + str(LR_Value))
#arcpy.AddMessage("This is the tie value " + str(tie_LR))
arcpy.AddMessage("This is the updated value " + str(fi))
del line
del uc
Here's the error I'm getting in the arcGIS message box:
Executing: CellAutoPnt F:\SWAT\NC\02088000_Post\Landuse\lu_pnt.shp
Start Time: Sat Oct 29 15:51:02 2011
Running script CellAutoPnt...
The current FID value is 1
The current GridCode value is 6.0
[0, 2, 1670, 1671, 1672]
[4.0, 4.0, 4.0, 6.0, 6.0]
This is the updated value 6.0
The current FID value is 2
[1, 3, 1671, 1672, 1673]
[4.0, 4.0, 6.0, 6.0, 6.0]
The current FID value is 3
The current GridCode value is 4.0
<type 'exceptions.AttributeError'>: 'Cursor' object has no attribute 'setValue'
Failed to execute (CellAutoPnt).
Failed at Sat Oct 29 15:51:07 2011 (Elapsed Time: 5.00 seconds)
Outcomes
