How the Reference Bend Baseline used?
848
10-28-2011 12:28 PM
gisCoder
Hi my friends,
Do you know how the Reference Bend Baseline parameter used in Simplify Tools in ArcGIS Desktop?
I don't know how Bend Simplify Method use it.
For example, I set Reference Bend Baseline  equal to 10 meters. So I think if an arc (an element of polyline) will be remove if it is less than 10 meters . Is this right?
I hope you will help me!
DanLee
by Esri Regular Contributor
No, it is not that simple. The following help topic has some details, if you are interested:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/How_Simplify_Line_works/00700000004600...
gisCoder
Thanks Dan Lee,
You helped me. And I know, about Generalization, you are very famous!
DanLee
You are welcome! Thanks for your kind comment.
Best regards.
