IWorkspace.ExecuteSQL does not work?
900
10-26-2011 02:11 AM
by Anonymous User
Not applicable
Hi
I tried to update a layer as below:
                    IWorkspaceProperties pp = mVersionedFeatureWorkspace as IWorkspaceProperties;
                    IWorkspaceProperty ap = pp.get_Property(esriWorkspacePropertyGroupType.esriWorkspacePropertyGroup, (int)esriWorkspacePropertyType.esriWorkspacePropCanExecuteSQL);
                    bool abc = ap.IsSupported;
                    if (abc)
                        IWorkspace pw = mVersionedFeatureWorkspace as IWorkspace;
                        pw.ExecuteSQL("update rwline set MaterialType = 4 where gid= 987654321");
the sql statement can be run without error, but unfortunately it also changed nothing. no specific record has been updated.
Is there something wrong I have?
Thank you.
by Anonymous User
Not applicable
Just found the caused issue.
If i am working on the default version, this statement works well.
but if i am working on the child version(IVersion mVersion = pDefaultVersionedWorpspace.FindVersion(sVersionName);), this statement doesn't work.
Is it a bug?
Regards,
Bing
by Anonymous User
Not applicable
Hi Bing,
To work on a version with SQLExecute you'll first need to set the versioned view via a stored procedure in your DBMS, otherwise it will only see the base table.
The following topics explain how to access geodatabase data with SQL and versioned views (previously called multiversioned views)
SQL access to enterprise geodatabase data—ArcMap | Documentation
What is a versioned view?—ArcMap | Documentation
