Using rest api I need the bbox values from a query in order to export an image. What is the easiest way from rest to query a field from a MapService and return the extent to then export that image?
Ok, that was helpful. Using the find feature I've retrieved the graphic and passed it to graphicsExtent. Question I have now is how to make graphic extent zoom to extent of the found object. This is without a map since I only want min max to create export image.
