How to assign a unique Value for cells
6616
6
10-25-2011 08:49 AM
ABDALLAMOHAMED
Hi..I wanted to assign a unique value (number) for each cell in the grid..I just wonder if any one can help me ..For my knowledge ArcMap 10 has no such tool, and I guess the only way to do it is through python programming..That is my thought, I may be wrong, don't know..Appreciate if some one can help me out..
Thanks a lot...
DanPatterson_Retired
Below provides some food for thought, please consult the appropriate help topics for other options.
>>> import numpy as np
>>> unique = np.arange(100)
>>> unique = unique.reshape(10,10)
>>> unique
array([[ 0,  1,  2,  3,  4,  5,  6,  7,  8,  9],
       [10, 11, 12, 13, 14, 15, 16, 17, 18, 19],
       [20, 21, 22, 23, 24, 25, 26, 27, 28, 29],
       [30, 31, 32, 33, 34, 35, 36, 37, 38, 39],
       [40, 41, 42, 43, 44, 45, 46, 47, 48, 49],
       [50, 51, 52, 53, 54, 55, 56, 57, 58, 59],
       [60, 61, 62, 63, 64, 65, 66, 67, 68, 69],
       [70, 71, 72, 73, 74, 75, 76, 77, 78, 79],
       [80, 81, 82, 83, 84, 85, 86, 87, 88, 89],
       [90, 91, 92, 93, 94, 95, 96, 97, 98, 99]])
>>> import arcpy
>>> out_raster = arcpy.NumPyArrayToRaster(unique)
>>> out_raster.save("c:/temp/testRaster")
ABDALLAMOHAMED
Thanks Dan..Let me give it a try and see, I never used Python before..??
markdenil
Occasional Contributor III
A non-Python way is to create a fishnet exactly the same as the grid you want: same extents, same cell size.
Build polygons from the fishnet lines
The polygons will all have unique feature ids.
convert the field of little square polygons to a raster with cells the same size as your little squares, using the (unique) feature ids as the value.
LukeWebb
Similar to the fishnet...this requires the correct tool (spatial analyst?) licenses but is very straight forward.
Use Raster to point tool - creates a point theme with a value field from the raster (These values I assume you do not require)
Then calculate a unique ID field in this dataset using field calculater --> FID / ObjectID
Finally, Point to Raster tool - select your uniqueID values field instead of the original value field.
Done.
Then
ABDALLAMOHAMED
Thanks all of you for your contributions..Appreciated..
LT1
Thanks a lot...
Hi mykotti,
I'm looking for simple examples of using numpy for GIS and this seems like a good one -- except I don't really can't guess (or conjure) a reason for creating a raster with a unique value for each cell.  Could you explain?  Thanks.  -- LT
