Archiving features question
778
04-15-2010 10:47 AM
JakeMatthys
Occasional Contributor II
I looked in the documentation but was unable to find an answer to the following question.  Will archiving in JTX 9.4 be available for feature classes that participate in a geometric network??
- Jake
TopeBello
Occasional Contributor III
Hi Jake,
At 10, ArcGIS Workflow Manager (formally known as JTX) will be taking advantage of the GDB archiving tools that come out of the box with ArcGIS. To answer your question, it works and will continue to work because I have turned on archiving on a dataset that participates in a geometric network and made edits in ArcMap. I was able to use the tools available on the workflow manager toolbar to inspect these individual features in an ArcMap session. With these tools, you can identify which job these edits were done, who did it and when it happened.
I hope this helps.
Tope
JakeMatthys
Thanks for the info topeb!!
