ArcHydro10 Drainage line processing error! Please please help!!!
3999
10-22-2011 03:48 AM
YacoubRaheem
I am running Windows XP Professional with Service Pack 3 (Pentium Dual-Core CPU, 3.07 GHz, 1.96 GB RAM). I have ArcGIS 10. I have installed the ArcGIS 10 Service Pack 3 (http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=66&MetaID=1807).
I installed what I thought was the latest version of ArcHydro 10 version 2.01.133 from here:
ftp://RiverHydraulics:river.1114@ftp.esri.com/ArcHydro/Setup10/.
I am delineating watersheds from 30m ASTER DEMs. I go through the standard pre-processing steps (Fill Sinks, Flow Direction, Flow Accumulation, Stream Definition, Stream Segmentation, Catchment Grid Delineation, Catchment Polygon Processing). Then I get to Drainage Line Processing and I get the following error:
Error HRESULT E_fail has been returned from a call to a COM component.
I tried uninstalling ArcHydro and then installing HEC-GeoHMS 10.0 (http://www.hec.usace.army.mil/software/hec-geohms/download.html) which automatically installs ArcHydro10 version 2.0.1.125. When I go through the same process, I get the same error.
This does not happen when I run this on Windows 7 machine (Intel Core i5, 2.53 GHz, 4GB Ram, 64-bit OS).
I am mainly a user and not so much a developer...
Please help!!!
Thank you,
Yacoub
email: yacoub@stanford.edu
V_StuartFoote
MVP Frequent Contributor
Yacoub,
You've got some answers in this thread.
Stuart
