unigisromy
"for" loop does not work with raster List (but it should)
Discussion created by unigisromy on Oct 15, 2011
Latest reply on Oct 22, 2011 by unigisromy
I have a quite simple problem but I could not get a pyhton script running...
I want to loop through a list of rasters stored in a GDB. I have reduced my code to a few lines but python exits with a "syntax error, invalid syntax". I tried to do the same with ListFeatureClasses but the code does not work either.
This is what I have done so far:
# Import arcpy module
import arcpy
# Check out any necessary licenses
arcpy.CheckOutExtension("3D")
arcpy.CheckOutExtension("spatial")
arcpy.CheckOutExtension("data management")
env.workspace = "D:\\ArcGIS\\Data\\raster.gdb"
rsList = arcpy.ListRasters("*_temp*","GRID")
print rsList
rsList.sort
print rsList #till this line scipt works fine
for rs in rsList
print rs
arcpy.AddMessage(str(rs))
arcpy.Delete_management(rs)
The code in red does not work... but it should. I´m puzzled. Any Ideas?
Thanks, Romy
Outcomes
