VBScript code cannot run under ArcGIS 10
956
5
10-14-2011 08:30 AM
YaoShen1
My VBScript code can run under ArcGIS9.3.1, but not under ArcGIS 10
' Create the Geoprocessor object
set gp = WScript.CreateObject("esriGeoprocessing.GPDispatch.1")
gp.AddToolbox "C:/Program Files/ArcGIS/Desktop10.0/ArcToolbox/Toolboxes/Conversion Tools.tbx"
Error Information
Error: Could not create object named "esriGeoprocessing.GPDispatch.1"
Source: WScript.CreateObject
Thank you
NobbirAhmed
Do you have VBA license installed? In 10, you need to install license separately. Request support for the license.
YaoShen1
Thank you very much for your reply:)
I can run VBA code in ArcGIS10 now. The VBScript code came from Model Builder. I made models in ArcGIS 9.3, then I exported as VBScript. But in 10, the Model Builder can't export VBScript code any more. It only supports Python Script... 😞
ChrisFox3
Occasional Contributor III
Is the machine that has ArcGIS 10 64 bit? If so check out the following KB article:
VBScript and JScript geoprocessing scripts do not run on a 64-bit Windows OS
YaoShen1
Thanks:o
But it is 32-bit Windows XP:(
JakubSisak
I beleive the location of toolboxed is incorrect. I think this is new to version 10.  The path to toolboxes on my machine is: "C:\Users\UserName\AppData\Roaming\ESRI\Desktop10.0\ArcToolbox\My Toolboxes"
