Hi all,
I have a simple Python script, which should check if a text file exists, and if not, create it:
filename = "%s\\%s.sql" % (sqlDir,viewName)
gp.AddMessage("Sql file: " + filename)
if not os.path.exists(filename):
ecc.
Running the script from an IDE (I use PyScripter) it works fine (the debugger also displays correctly the filename)
Running it from the ArcToolbox, the directory part of the file path is removed, i.e. gp.AddMessage("Sql file: " + filename) prints only "\\viewName", so the line
Can anyone explain me why this weired behaviour ?
