Hi,I was searching for a way to programmatically create a polygon with a hole, as there isn't any obvious way of doing this in the documentation, I started fumbling around on my own. I came up with this test script:gjPolygonWithHole = {
"type": "Polygon",
"coordinates": [
[[-88.684979400000032, 38.154361399999985], [-88.666690199999962, 38.154329800000042], [-88.67131005539963, 38.154337782166039], [-88.675899944207302, 38.154345712555887], [-88.675899944207302, 38.150691003182175], [-88.67131005539963, 38.150691003182175], [-88.67131005539963, 38.147037172952786], [-88.675899944207302, 38.147037172952786], [-88.685066075460313, 38.147037172952786], [-88.684979400000032, 38.154361399999985]],
[[-88.680463013034853, 38.152519617763254], [-88.680463013034853, 38.15068957953018], [-88.678182297717754, 38.15068957953018], [-88.678182297717754, 38.152519617763254], [-88.680463013034853, 38.152519617763254]]]
def main():
outputShapeDir = r"c:\temp"
outputShapeFile = r"test.shp"
spatialRef = r'X:\Nadel&Gussman\McLeansboro\Sections.prj'
newFC = arcpy.CreateFeatureclass_management( outputShapeDir, outputShapeFile, "POLYGON", "", "", "", spatialRef )
cur = arcpy.InsertCursor(newFC)
array = arcpy.Array()
point = arcpy.Point()
# Create a list to store the features
features = []
# Read the coordinates
for part in gjPolygonWithHole["coordinates"]:
for coordPair in part:
point.X = coordPair[0]
point.Y = coordPair[1]
array.add(point)
feat = cur.newRow()
feat.shape = array
cur.insertRow( feat )
if __name__ == '__main__':
import arcpy
main()
Amazingly, it works (I'm not really sure how, since I don't do anything to separate the interior from the exterior, other than suddenly switch winding order):Unfortunately, this doesn't work in all polygon-with-a-hole cases that I am working with. So...I noticed the seemingly useful "AsShape" functionality here. Specifically, (notice the AsShape example on doing just this at the bottom of the page i linked).I put together a little sample script to test this:gjPolygonWithHole = {
"type": "Polygon",
"coordinates": [
def main():
feat = cur.newRow()
feat.shape = arcpy.AsShape( gjPolygonWithHole )
import arcpy
main()
FAILURE:The hole is completely ignored. Any clue as to why?Regarding holes, I found this thread, and adapted their method to my test script + data. It almost works:Here's my example code:gjPolygonWithHole = {
"type": "Polygon",
"coordinates": [
def main():
features = []
array.add(point)
null_point = arcpy.Point()
array.add(null_point)
feat = cur.newRow()
feat.shape = arcpy.Polygon( array )
import arcpy
main()
Any ideas why this doesn't work? Why is creating geometry such a hassle with arcpy? Why do some methods work and some do not? Most likely I'm missing something obvious...Thanks,Dustin
