yaotzin
Deploying MXD on arcGIS Server 10
Discussion created by yaotzin on Oct 4, 2011
Latest reply on May 8, 2012 by bettsdaniel
Hi everyone
I got problem with deploying MXd file on Server. After 'Add new service' option I trying start new service but, I got an exception like:
<Msg time='2011-10-04T11:55:19' type='ERROR' code='10800' target='overview.MapServer' methodName='MapServer.Connect' machine='VM-AGS-PROJ' process='2972' thread='3344'>The format of the document C:\arcDoc_doc\Documents\application\overview.mxd is invalid.</Msg>
<Msg time='2011-10-04T11:55:19' type='ERROR' code='1016' target='overview.MapServer' machine='vm-ags-proj' thread='3036' elapsed='20.04700'>Server Object instance creation failed on machine vm-ags-proj.    The format of the document C:\arcDoc_doc\Documents\application\overview.mxd is invalid.  </Msg>
<Msg time='2011-10-04T11:55:19' type='ERROR' code='1008' target='overview.MapServer' thread='3080'>Configuration overview.MapServer can not be started.</Msg>
I using ArcGIS Server 10 with SP2 on Windows Server 2008. All MXD work ok in ArcMap and ArcCatalog.
On another machine everything works fine. Can someone give me any hint what can be wrong in that case?
Outcomes
