When authoring the layer in ArcMap, you can assign a display field for a layer and typically DISPLAY field is set for layers that can be queried. In this case since this is a RASTER layer, I assume it may not support a DISPLAY field. please check if you are able to assign a display field in ArcMap and if this layer can be queried.
