DASH
Export Maps with Joins
Discussion created by DASH on Oct 3, 2011
Latest reply on Feb 8, 2012 by DASH
I've run into a bit of a stumbling block when trying to use a join within the context of a dynamic layer. I've included some details about my test environment; I've also included a working dynamic layers rendering request without a join and a broken request with a join. I am hoping someone is able to spot my error.
Environment:
    ArcServer 10.1 Beta 1
    ArcSDE 9.1
    Oracle 10gR2
The connection within the MapService is registered as the schema owner (VRIMSD_ADMIN); this user is not a DBA.
The VRIMSD_ADMIN.FOREST_COVER_OBJECT table is a spatially enabled SDO table; VRIMSD_ADMIN.FOREST_COVER_OBJECT.FOREST_COVER_OBJECT_ID is registered as the obid column.
The VRIMSD_ADMIN.VEGETATION_COVER_POLYGON_EST table does not have any spatial components and is registered with SDE. There is a 1-1 relationship from the FOREST_COVER_OBJECT table to the VEGETATION_COVER_POLYGON_EST table.
*** WORKS ***
    "id": "VRIMSD_ADMIN.FOREST_COVER_OBJECT",
    "source": {
           "type": "dataLayer",
      "dataSource":
            "type": "table",
            "workspaceId": "VegWrk",
            "dataSourceName": "VRIMSD_ADMIN.FOREST_COVER_OBJECT"
    "drawingInfo":
      "renderer":
        "type": "simple",
        "symbol":
          "type" : "esriSFS",
          "style" : "esriSFSSolid",
          "color" : [166,36,0,255],
          "outline" :
            "type" : "esriSLS",
            "style" : "esriSLSSolid",
            "color" : [0,255,0,255],
            "width" : 2
        "description": ""
      "transparency": 60
*** RETURNS A WHITE IMAGE ***
    "source": {
      "type": "joinTable",
      "leftTableSource":
      "dataSource":
            "type": "table",
      "rightTableSource":
            "dataSource":
               "type": "table",
                "dataSourceName": "VRIMSD_ADMIN.VEGETATION_COVER_POLYGON_EST"
      "leftTableKey": "VRIMSD_ADMIN.FOREST_COVER_OBJECT.FOREST_COVER_OBJECT_ID",
      "rightTableKey": "VRIMSD_ADMIN.VEGETATION_COVER_POLYGON_EST.FOREST_COVER_OBJECT_ID",
      "joinType": "esriLeftOuterJoin"
    "drawingInfo":
      "renderer":
        "type": "simple",
        "symbol":
          "type" : "esriSFS",
          "outline" :
            "type" : "esriSLS",
            "width" : 2
        "description": ""
Outcomes
