dustfurn
problem creating arcpy polygon
Discussion created by dustfurn on Sep 29, 2011
Latest reply on Sep 30, 2011 by mnakleh
I was having a problem creating certain polygons programmatically, so I put together this simple example to illustrate the issue.
The following code works as expected (creates a simple square):
outputFeatureClass = r"c:\temp\test.shp"
coordList = [[0, 0],
             [0, -0.01],
             [.01, -.01],
             [.01, 0],
             [0, 0]]
def main():
    array = arcpy.Array()
    point = arcpy.Point()
    # Create a list to store the features
    features = []
    # Read the coordinates
    for coordPair in coordList:
        point.X = coordPair[0]
        point.Y = coordPair[1]
        array.add(point)
    polygon = arcpy.Polygon(array)
    # Append to the feature list
    features.append(polygon)
    # Copy the features to an output feature class
    arcpy.CopyFeatures_management(features, outputFeatureClass)
if __name__ == '__main__':
    import arcpy
    main()
However, if i change coordList to:
             [0, -0.001],
             [0.001, -0.001],
             [0.001, 0],
             [0, 0]]
The script completes successfully, but the resulting geometry is a "null" shape, according to the check geometry tool.
My guess is that the vertices are all getting merged at some point?  If so, why, and how can i prevent it?
Dustin
Outcomes
