lscharen
Navigation toolbar is in a corrupt state if created after map.onLoad
Discussion created by lscharen on Sep 20, 2011
Latest reply on Sep 21, 2011 by DSwingley-esristaff
I found this issue is a much larger application and narrowed it down to the Navigation toolbar.  If the navToolbar is created *after* the map.onLoad event is fired, it is initialized in a corrupt state.  There is only a single entry in the _extents array, but the _extentCursor is set to -1.  This causes isLastExtent() and isFirstExtent() to both return false and triggers a javascript error when trying to zoomToNext() or zoomToPrev().
I've modified the Navigation Toolbar example to illustrate the problem.  Load the example and click on the "Prev Extent" button to get the error.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Navigation toolbar</title>
    <style type="text/css">
      @import "http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css";
    </style>
    <script type="text/javascript">dojoConfig = { parseOnLoad:true }</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script>
      dojo.require("esri.map");
      dojo.require("esri.toolbars.navigation");
      dojo.require("dijit.form.Button");
      dojo.require("dijit.Toolbar");
      var map, navToolbar;
      function init() {
        esriConfig.defaults.map.sliderLabel = null;
        var startExtent = new esri.geometry.Extent({"xmin":-16358747,"ymin":2847778,"xmax":3678761,"ymax":12866532,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map",{extent:startExtent});
  // *** BUG ** : Create the navigation toolbar after the map is loaded
  dojo.connect( map, 'onLoad', function() {
      navToolbar = new esri.toolbars.Navigation(map);
   dojo.connect(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
        map.addLayer(new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"));
      function extentHistoryChangeHandler() {
        dijit.byId("zoomprev").disabled = navToolbar.isFirstExtent();
        dijit.byId("zoomnext").disabled = navToolbar.isLastExtent();
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="navToolbar" data-dojo-type="dijit.Toolbar">
      <div data-dojo-type="dijit.form.Button" id="zoomin"  data-dojo-props="iconClass:'zoominIcon', onClick:function(){navToolbar.activate(esri.toolbars.Navigation.ZOOM_IN);}">Zoom In</div>
      <div data-dojo-type="dijit.form.Button" id="zoomout" data-dojo-props="iconClass:'zoomoutIcon', onClick:function(){navToolbar.activate(esri.toolbars.Navigation.ZOOM_OUT);}">Zoom Out</div>
      <div data-dojo-type="dijit.form.Button" id="zoomfullext" data-dojo-props="iconClass:'zoomfullextIcon', onClick:function(){navToolbar.zoomToFullExtent();}">Full Extent</div>
      <div data-dojo-type="dijit.form.Button" id="zoomprev" data-dojo-props="iconClass:'zoomprevIcon', onClick:function(){navToolbar.zoomToPrevExtent();}">Prev Extent</div>
      <div data-dojo-type="dijit.form.Button" id="zoomnext" data-dojo-props="iconClass:'zoomnextIcon', onClick:function(){navToolbar.zoomToNextExtent();}">Next Extent</div>
      <div data-dojo-type="dijit.form.Button" id="pan" data-dojo-props="iconClass:'panIcon', onClick:function(){navToolbar.activate(esri.toolbars.Navigation.PAN);}">Pan</div>
      <div data-dojo-type="dijit.form.Button" id="deactivate" data-dojo-props="iconClass:'deactivateIcon' ,onClick:function(){navToolbar.deactivate();}">Deactivate</div>
    </div>
    <div id="map" style="width:1024px; height:512px; border:1px solid #000;"></div>
  </body>
</html>
Outcomes
