deano2020
Auto load ArcGIS for AutoCAD Ribbon
Discussion created by deano2020 on Sep 19, 2011
Latest reply on Oct 6, 2017 by beckycb78
I want to be able to auto-load the ArcGIS for AutoCAD ribbon when starting up AutoCAD 2010.  Can I just copy and paste a .lsp file in the 'Support' folder of AutoCAD?  If so, what scrip do I need to put into the .lsp file to auto-load the ribbon?
Also, am I correct in assuming you can only access map services with ArcGIS for AutoCAD?...you aren't able to connect to geodatabases?
Thanks in advance!
Outcomes
