Hi, extracting from the arcgis sample code there is a method that calling webmap for features
how do i not rellying on webmap but to get the feature from offline layer.?
If I would like to create a manual form
-(void)featureTemplatePickerViewController:(FeatureTemplatePickerViewController*) featureTemplatePickerViewController didSelectFeatureTemplate:(AGSFeatureTemplate*)template forFeatureLayer:(AGSFeatureLayer*)featureLayer{
//set the active feature layer to the one we are going to edit
self.activeFeatureLayer = featureLayer;
//create a new feature based on the template
_newFeature = [self.activeFeatureLayer createFeatureWithTemplate:template];
//Add the new feature to the feature layer's graphic collection
//This is important because then the popup view controller will be able to
//find the feature layer associated with the graphic and inspect the field metadata
//such as domains, subtypes, data type, length, etc
//Also note, if the user cancels before saving the new feature to the server,
//we will manually need to remove this
//feature from the feature layer (see implementation for popupsContainer:didCancelEditingGraphicForPopup: below)
[self.activeFeatureLayer addGraphic:_newFeature];
//Iniitalize a popup view controller
self.popupVC = [[[AGSPopupsContainerViewController alloc] initWithWebMap:self.webmap forFeature:_newFeature usingNavigationControllerStack:NO] autorelease];
self.popupVC.delegate = self;
//Only for iPad, set presentation style to Form sheet
//We don't want it to cover the entire screen
if([[UIDevice currentDevice] isIPad])
self.popupVC.modalPresentationStyle = UIModalPresentationFormSheet;
//Animate by flipping horizontally
self.popupVC.modalTransitionStyle = UIModalTransitionStyleFlipHorizontal;
//First, dismiss the Feature Template Picker
[self dismissModalViewControllerAnimated:NO];
//Next, Present the popup view controller
[self presentModalViewController:self.popupVC animated:YES];
[self.popupVC startEditingCurrentPopup];
