My legend never displayed. The alert message I put inside onLayersAddResult never fired up. I do not know what is wrong. I attached code here. Please help and thanks.
function init() { var initExtent = new esri.geometry.Extent({ "xmin": 2940165, "ymin": 9946407, "xmax": 3233783, "ymax": 10199898, "spatialReference": { "wkid": 2277 } }); map = new esri.Map("map", { extent: initExtent }); // alert("AFTER map init") //add the legend dojo.connect(map,'onLayersAddResult',function(results) { alert("in the layer addresults"); var layerInfo = dojo.map(results, function(layer,index) { return {layer:layer.layer,title:layer.layer.name}; }); if(layerInfo.length > 0) { alert("layerinfo "+layerinfo); var legendDijit = new esri.dijit.Legend({ map:map,layerInfos:layerInfo},"SideInfo"); legendDijit.startup(); }else { alert("layerinfo is 0"); } }); var tiledMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://wpdrgisdev1.coacd.org/ArcGIS/rest/services/FindYourWatershed/MapServer"); map.addLayer(tiledMapServiceLayer); alert("after layer is added "); dojo.connect(map, 'onLoad', function(map){ dojo.connect(dijit.byId('map'), 'resize', resizeMap); }); locator = new esri.tasks.Locator("http://wpdrgisdev1.coacd.org/ArcGIS/rest/services/COAGeocode/GeocodeServer"); dojo.connect(locator, "onAddressToLocationsComplete", showAddressResults); map.infoWindow.resize(200, 125); dojo.byId("address").value="505 barton springs rd"; //esri.hide("map"); }
I found out why. I used addlayer function to add all the layers from one service. As a result onLayersAddResult is never fired. Please see this post for more.
