import arcpy, math arcpy.env.overwriteOutput = True arcpy.env.workspace = r"C:\GIS\Temp\test.gdb" tempworkspace = arcpy.env.workspace in_poly_fc = r"C:\GIS\Temp\test.gdb\CirclesFeatureClass" clip_lines_fc = r"ClipLines" sum_lines_fc = r"SumClipLines" #converting an existing fc with circles to Geometry objects geometries = arcpy.CopyFeatures_management(in_poly_fc,arcpy.Geometry()) for feature in geometries: #obtaining a centroid of the circle centroid via Geometry class attribute centroid_Point = feature.trueCentroid centroid_xy = [] #obtaining XY coordinates of the centroid via Point class attribute centroid_xy.append(centroid_Point.X) centroid_xy.append(centroid_Point.Y) #obtaining the radius #have to add a small overhead value to make sure the radius end point will overshoot the polygon #otherwise may get undershooting lines which depends on the precision of the coordinates #and XY tolerance of the source data radius = math.sqrt(feature.area / math.pi) + 1 #supply the list of angles for bearing bearing_angles = [0,60,120,180,240,300,360] #creating bearing angles table and adding fields bearing_table = arcpy.CreateTable_management(tempworkspace,"BearingDataTable") arcpy.AddField_management(bearing_table,"Xcoord","Double") arcpy.AddField_management(bearing_table,"Ycoord","Double") arcpy.AddField_management(bearing_table,"Bearing","Double") arcpy.AddField_management(bearing_table,"Distance","Double") #inserting all required lines constructed from centroid with the radius and bearing angle with arcpy.da.InsertCursor(bearing_table,["Xcoord","Ycoord","Bearing","Distance"]) as ins_cursor: for bearing_angle in bearing_angles: ins_cursor.insertRow((centroid_xy[0],centroid_xy[1],bearing_angle,radius)) del ins_cursor #projected coordinate system used for output lines feature classes generated project_coordsys = """PROJCS['NAD_1927_StatePlane_Alabama_East_FIPS_0101',GEOGCS['GCS_North_American_1927', DATUM['D_North_American_1927',SPHEROID['Clarke_1866',6378206.4,294.9786982]],PRIMEM['Greenwich',0.0], UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0], PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-85.83333333333333], PARAMETER['Scale_Factor',0.99996],PARAMETER['Latitude_Of_Origin',30.5], UNIT['Foot_US',0.3048006096012192]];-17948200 -43887100 3048,00609601219; -100000 10000;-100000 10000;3,28083333333333E-03;0,001;0,001;IsHighPrecision""" arcpy.BearingDistanceToLine_management(bearing_table,clip_lines_fc,"Xcoord","Ycoord", "Distance","Feet","Bearing",spatial_reference=project_coordsys) #adding each circle's 8 lines in iteration to the sum output line feature class arcpy.Append_management(clip_lines_fc,sum_lines_fc,"NO_TEST") #deleting temp feature classes to avoid locking issues at next iteration arcpy.Delete_management(bearing_table) arcpy.Delete_management(clip_lines_fc) #cutting each circle in the polygon feature class by using the lines obtained earlier arcpy.FeatureToPolygon_management([in_poly_fc,sum_lines_fc],"Quadrants","#","ATTRIBUTES","#")
