merlich
Tile Caching
Discussion created by merlich on Aug 30, 2011
Latest reply on Aug 30, 2011 by merlich
When zooming and panning, it appears that the control will keep making the same REST calls to the service for the tiles to display (have only tested using local data, but I'd assume this also applies to remove services as well?).  Most map tiling applications use caching to keep a little history of previously loaded tiles and some use predictive cache to pre-cache tile from anticipated movements.  Does the runtime use any of these techniques if so, how can it be turned on and/or controlled to increase performance/drawing rates?
Outcomes
