Add button to PopupInfo
5940
7
08-26-2011 04:46 AM
lavoillottenicolas
Hello
is it possible to add components to PopUpInfo : e.g a simple button ?
like for the link "zoom on" I would like add a button that open the widget "google street" on the current location of my map
RobertScheitlin__GISP
Lavoillette,
   That would involve getting the PopUpRendererSkin.mxml from the Flex  API download in the  arcgis_api_for_flex_2_4\ArcGIS_Flex\skins\src\com\esri\ags\skins folder  and adding a new button to the Declarations section and in the  commitProperties function adding to the popup just like the zoom to  button.
lavoillottenicolas
Thanks Roberts,
is it possible to override class PopupRendererSkin  with my own renderer, instead of change the class PopupRendererSkin ?
Lavoillette,
   Sure just use that as your starting point, for can use any skin you want with the PopUp.
lavoillottenicolas
Hi Roberts,
I created my own skin "CustomPopUpRendererSkin" with the source : PopUpRenderer, and my component "CustomPopUpRenderer" derived from PopupRenderer
When I Use my component : PopupRenderer, my skin : CustomPopUpRendererSkin is never called ? only the PopUpRendererSkin is called
Into the widget "LocateWidget" :
private function showLocation(data:Object):void
                hideInfoWindow();
                graphicsLayer.clear();
                var ptGraphic:Graphic = new Graphic();
                ptGraphic.geometry = data.point;
                graphicsLayer.add(ptGraphic);
                var popUpInfo:PopUpInfo = new PopUpInfo();
                popUpInfo.title = data.title;
                popUpInfo.description = data.content;
  // My component
                var infoWindowRenderer:ClassFactory = new ClassFactory(CustomPopUpRenderer);
                infoWindowRenderer.properties = { popUpInfo: popUpInfo };
                graphicsLayer.infoWindowRenderer = infoWindowRenderer;
                popUpRenderer.popUpInfo = popUpInfo;
                popUpRenderer.graphic = ptGraphic;
                if (map.scale > zoomScale)
                    map.scale = zoomScale;
                map.centerAt(data.point);
                infoWindowShow();
My CustomPopUpRenderer.as
package com.esri.viewer.components
import com.esri.ags.webmap.PopUpRenderer;
public class CustomPopUpRenderer extends PopUpRenderer
  public function CustomPopUpRenderer()
   //TODO: implement function
   super();
My CustomPopUpRendererSkin.mxml
<s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
             xmlns:s="library://ns.adobe.com/flex/spark"
             xmlns:mx="library://ns.adobe.com/flex/mx"
             xmlns:esri="http://www.esri.com/2008/ags"
             xmlns:supportClasses="com.esri.ags.skins.supportClasses.*"
             width="270"
             maxHeight="300"
             preinitialize="skin_preinitializeHandler(event)">
<fx:Metadata>[HostComponent("com.esri.viewer.components.CustomPopUpRenderer")]</fx:Metadata>
    <fx:Script>
        <![CDATA[
        ..... currently the source of PopUpRendererSkin.mxml
Nicolas
Regards
Nicolas,
   The way use a particular PopUpRenederSkin is just one line of code. You do not need a CustomPopUpRenderer.as all you need is your CustomPopUpRendererSkin.mxml and this line in your widget.
popUpRenderer.setStyle("skinClass", Class(widgets.MyPopUps.PopUpRendererSkin));
So your whole function would look like this:
                hideInfoWindow();
                var infoWindowRenderer:ClassFactory = new ClassFactory(PopUpRenderer);
                infoWindowShow();
Of course you will need to import your PopUpRendererSkin as well:
import widgets.MyPopUps.PopUpRendererSkin;
lavoillottenicolas
thanks Roberts,
it works
nicolas
regards
TroySchmidt
When I do this I am trying to access this.hostcomponent in the SkinClass and it is giving me null.  I am trying to do additional processing by overriding the commitProperties function.  Is this methodology wrong?
