Following script imported from Model builder. I want run it for other states, it did not work. If python does not support "arcpy.gp.RasterCalculator_sa" funtion, if there any away to perform following expresion using a python script?
Raster calculator expresion: Con("ia_corn" == 1,"soilmu_in_90")
Where ia_corn is a binary gird ( 1 and 0) and soilmi_in_90 an interger grid. I want to import values from soilmi_in_90 to ia_corn.
# cornMUKEY.py
# Created on: 2011-08-19 15:54:25.00000
# (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# Local variables:
in_corn ="K:\\CropLand\\STATE.gdb\\in_corn"
soilmu_in_90 = "K:\\STATE_ MUKEY\\RASTER.gdb\\soilmu_in_90"
csoilmu_in = "K:\\STATE_ MUKEY\\CORN_MUKEY.gdb\\csoilmu_in"
# Process: Raster Calculator
arcpy.gp.RasterCalculator_sa("Con(\"%in_corn%\" == 1,\"%soilmu_in_90%\")", csoilmu_in)
print arcpy.GetMessages
Warning (from warnings module):
File "<string>", line 1
SyntaxWarning: import * only allowed at module level
File "K:\SCRIPT\Python_Script\cornMUKEY.py", line 21, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\geoprocessing\_base.py", line 474, in <lambda>
return lambda *args: val(*gp_fixargs(args))
ExecuteError: ERROR 000539: Error running expression: rcexec() <type 'exceptions.RuntimeError'>: ERROR 000732: Input Raster: Dataset %soilmu_in_90% does not exist or is not supported
Failed to execute (RasterCalculator).
