i need a mapviewer for my geoportal and i like the javascript webmap viewer (http://www.arcgis.com/home/webmap/viewer.html). i need to display wms, kml and arcgis mapservices in the viewer and the online version does it all.
my question is: may i take the source code of this viewer and rewrite it to fit into my portal?
As far as I know, that's not possible. Unlike with the Flex Viewer and Siliverlight Viewer, there is no "JavaScript Viewer" which you can download and rewrite.
The closest thing you can do simply is to use ArcGIS.com to generate a map template. The help file entry Using ArcGIS.com Templates might help.
Otherwise, you'll need to build your own application using the samples as a starting point.
