crick70
Fc to FC with joined field slow
Discussion created by crick70 on Aug 17, 2011
Latest reply on Aug 18, 2011 by khartling-esristaff
Using model builder in ArcGIS 10. I add a Join to a field then try to create a new Feature Class using the Feature Class to Feature Class tool.  For some reason it takes hours to run this part of the tool.  A simple FC to FC runs in seconds but once I add a join it, it can take 5 hours to run. I have tried in on machines with straight ArcGis 10 on it (no SP) and ones with SP1 and SP2.  The problem is the same.
Has anyone else experience this problem and discovered a work around.
Note these model run fine in 9.3.1
Cheers
Chris
Outcomes
