We are trying to create a drill-drown geo-coder similar to what see in tom-tom/garmin systems in your vehicle where you select state, then select city, then select street name. Using the 'Find Local Layer' with a little re-tooling, we have been able to search for attributes in the map meta-data. However, we have not been able to add a filter with the search text. In other words, we can search for a street by the first few letters entered by the user, but have not found a way to also add in the city/state criteria to the search. Are there other ways to the use the FindTask to provide multiple search criteria rather than just setting the 'SearchText' field in the FindParameters, is there an extended version of the FindParameters that we are missing, or are we way off base and possibly you have some other suggestions on how we can achieve the same searching capability?
Mike
