pml
Xcode: Library folder hidden
Discussion created by pml on Aug 13, 2011
I came across this problem today - thought I would share it since someone else may have the same issue.
Using Xcode 4, I was trying to add libArcGIS.a to the Link Binaries with Libraries section of the Xcode project. This is step 1 of the link below. This file is located at ${HOME}/Library/SDKs/ArcGIS/iOS.sdk/usr/local/lib. The problem was that the Library folder was hidden so I could not navigate to libArcGIS.a. After a little digging, someone suggested to do "chflags nohidden </path/to/folder>" at a Terminal window. Sure enough, the folder now appears and I can browse to it in Xcode.
http://help.arcgis.com/en/arcgismobile/10.0/apis/iOS/2.0/concepts/index.html#/Creating_a_New_Xcode_Project/00pw00000044000000/ESRI_SECTION1_7F3FAA5F5C2C481D848A9029112380C0/
Outcomes
