tbecker@igg
Multimodal utility networks
Discussion created by tbecker@igg on Aug 8, 2011
Latest reply on Aug 8, 2011 by RAnderson-esristaff
i would like to use the Schematics extension to create the connectivity between different utility networks. My created a database schema on my own in order to put all incoming features into special classes and these classes are connected by relationships. So the implicit connectivity between objects is given by these relationsships. I tried to use the schematics extension but it won't work. Due to some reason, the nodes are not connected to the links. I tried to fix the problem and stumbled over the Schematics example in ArcTutor with the InsidePlant example. There some root_nodes and links are used with included attributes. My question is, is there a documentation for this example available which describes how these root_stuff and all these attributes and fields can be used to create a schematic dataset?
Many thanks for help.
Thomas
Outcomes
