View Map In SplitViewController
3263
08-05-2011 02:46 AM
FaisalSabri
Hi All ,
i want to add points ( (X,Y) as location on the map ) on table view in the Left of the Split view Controller and my map on the details view on the Right is there a way to do that ?? is it possible ??
ChrisMahlke
Hi All ,
It's possible.  You should start out by using Apple's SplitViewController template that comes with Xcode.  The RootViewController on the left pane already contains a UITableView, you can store your locations in the table and add the map to the detailsviewcontroller on the right pane.
see:
http://developer.apple.com/library/ios/#featuredarticles/ViewControllerPGforiPhoneOS/iPadControllers...
At least, if I understand your question correctly.
FaisalSabri
Dear cmahlke ,
Thank u for you answer , that's exactly what i want to do ,
but , when i tried to create a project with SplitViewController template that comes with Xcode , i have to add the ESRI Reference like the "libArcGIS.a" Framework and the ArcGISBundle , now in the user interface i do not have any ESRI Controls , so i have coped the map from ESRI project i have created in xcode and paste it in the interface to use it and add the ArcGis.h to project , i got 355 Error ,
i don't really what to do !!
Please see attached Images
NimeshJarecha
If you create a XCode project with any iOS template then you should follow steps outlined in the below document to work with ArcGIS for iOS liberary.
http://help.arcgis.com/en/arcgismobile/10.0/apis/iOS/2.0/concepts/index.html#/Creating_a_New_Xcode_P...
Regards,
Nimesh
FaisalSabri
Dear Nimesh,
Thanks A lot for your Help !!
it's working perfect now 😄
