philjw
Select by Attribute Combobox Help
Discussion created by philjw on Aug 3, 2011
Latest reply on Aug 4, 2011 by philjw
Im trying to write code for a combobox toolbar which will populate itself with unique features and then select by attribute the correct feature.  Much like the code discussed here http://forums.esri.com/Thread.asp?t=251246&c=93&f=992
My code looks like this but I need help figuring it out.  Any help?
rivate Sub UserForm_Initialize()
GetDistinctValues UserForm2.ComboBox1, "TOWNSHIP"
GetDistinctValues UserForm2.ComboBox2, "RANGE"
GetDistinctValues UserForm2.ComboBox3, "SECTION"
End Sub
Sub GetDistinctValues(cboTemp As ComboBox, strFieldName As String)
Dim pMxDoc As IMxDocument
Dim pFeatureLayer As IFeatureLayer
Set pMxDoc = ThisDocument
Set pFeatureLayer = pMxDoc.FocusMap.Layer(1)
Dim pDataStatistics As IDataStatistics
Set pCursor = pFeatureLayer.Search(Nothing, False)
Set pDataStatistics = New DataStatistics
pDataStatistics.Field = strFieldName
Set pDataStatistics.Cursor = pCursor
Set pEnumVariantSimple = pDataStatistics.UniqueValues
Dim value As Variant
value = pEnumVariantSimple.Next
' setting FCursor
Set pFCursor = pFClass.Search(Nothing, False)
Set pFeature = pFCursor.NextFeature
' determine the unique values of user selected fieldname
Dim iFieldNum As Integer
iFieldNum = pFClass.Fields.FindField(strFieldName) 'is this where I put my field name?
Do Until pFeature Is Nothing
pUniqueRenderer.AddValue pFeature.value(iFieldNum), "", Nothing
Loop
' loop over the pUniqueRenderer and list values to listbox
Dim iCount As Integer
cboTemp.Clear
For iCount = 0 To pUniqueRenderer.ValueCount - 1
cboTemp.AddItem pUniqueRenderer.value(iCount)
Next iCount
End Sub
Public Sub SelectMapFeatures()
  Dim pMap As IMap
  Dim pActiveView As IActiveView
  Dim pFeatureSelection As IFeatureSelection
  Dim pQueryFilter As IQueryFilter
  Set pMxDoc = Application.Document
  Set pMap = pMxDoc.FocusMap
  Set pActiveView = pMap
  'For simplicity sake let's use the first layer in the map
  If Not TypeOf pMap.Layer(1) Is IFeatureLayer Then Exit Sub
  Set pFeatureLayer = pMap.Layer(1)
  Set pFeatureSelection = pFeatureLayer
  'Create the query filter
  Set pQueryFilter = New QueryFilter
  pQueryFilter.SubFields = "TOWNSHIP,RANGE,SECTION"
  pQueryFilter.WhereClause = "TOWNSHIP = '" & UserForm2.ComboBox1.value & "' or RANGE = '" & UserForm2.ComboBox2.value & "' or SECTION = " & UserForm2.ComboBox3.value & "'"
  'Invalidate only the selection cache
  'Refresh the old selection if any to erase it
  pActiveView.PartialRefresh esriViewGeoSelection, Nothing, Nothing
  'Perform the selection
  'Debug.Print SelectFeature
  pFeatureSelection.SelectFeatures pQueryFilter, esriSelectionResultNew, False
  'pFeatureSelection.CombinationMethod = esriSelectionResultNew
  'Refresh again to draw the new selection
End Sub
Outcomes
