I am trying to update the feature class attributes which is inside a geometric network along with FMAutoUpdaters enabled. I've created a version to edit the session (C#) and then disabled the AutoUpdaters for performing the edits. After setting all the new values to the feature class, I am trying to Reconcile it and Post.
Reconciling is executing without any error, When I try to check for .CanPost() method, it is returning false. I am using the below code...
private bool PostVersion(IFeatureWorkspace pWorkSpace, string strVersionName)
IVersionedWorkspace pVWSpace = null;
//IVersionEdit pVSEdit = null;
IVersionEdit3 pVSEdit = null;
IVersion pVersion = null;
IWorkspaceEdit pWSEdit = null;
try
pVWSpace = (IVersionedWorkspace)pWorkSpace; //Get the current versioned workspace
pVersion = (IVersion)pVWSpace.FindVersion(strVersionName);
string sParentVersionName = null;
pVWSpace = (IVersionedWorkspace)DoStartEditing(pWorkSpace);
pVSEdit = (IVersionEdit3)pVWSpace;
if (pVersion.HasParent())
sParentVersionName = pVersion.VersionInfo.Parent.VersionName;
else { return false; }
if ((sParentVersionName != null))
pWSEdit = (IWorkspaceEdit)pWorkSpace;
pWSEdit.StopEditOperation();
//Perform the Reconcile
if (pVSEdit.Reconcile(sParentVersionName))
//If conflicts are detected, abort operation
//pVSEdit.AbortOperation();
return false;
else
pVersion = pVSEdit.StartEditingVersion;
if (pVSEdit.CanPost())
pVSEdit.Post(sParentVersionName);
return true;
catch (Exception ex)
if (ex.Message == System.Configuration.ConfigurationManager.AppSettings["ERR_VERSION_EXIST"].ToString())
return false;
ErrorLog.WriteErrorLog("In clsSynchronizeAboveGround.cs inside PostVersion :" + ex.Message.ToString());
finally
DoStopEditing(pWorkSpace);
GC.Collect();
return false;
Any help???
~Paul
