System.Windows.Controls - Assembyl error
464
07-29-2011 02:01 AM
asdfasdf2
Hallo
installed software:
vs2010 pro
wpf toolkit on codeplex (WPF Toolkit February 2010 (Version 3.5.50211.1))
expression blend 4 sdk for .net (Version 2.0.20621.0)
i have using the example InteractiveWPFSDKSource from: http://help.arcgis.com/en/webapi/wpf/help/InteractiveWPFSDKSource.zip
and have this compiler error in the QueryRelatedRecords.xaml example.
<UserControl x:...
xmlns:common="clr-namespace:System.Windows;assembly=System.Windows.Controls"
and a problem with set the VisibleLayers:
<esri:ArcGISDynamicMapServiceLayer ID="DynamicMapWellsLayer" VisibleLayers="0,1" Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer" />
I set all references correct, i think. 😉
Thanks.
JenniferNery
What error message are you getting exactly?
If you are getting the blue squiggly line on VisibleLayers with this error:
Unable to cast object of type 'Microsoft.Expression.DesignModel.DocumentModel.DocumentPrimitiveNode' to type 'Microsoft.Expression.DesignModel.DocumentModel.DocumentCompositeNode'.
this is known design-time error that appears when you have XAML open.
Since you say the error includes "System.Windows.Controls" I cannot think of an error related to this that shows with "VisibleLayers" property set. I think it would help if you share the actual error message and code so we can reproduce it here too. Thanks!
killram
hello
i have a blue squiggly line on xmlns:common="clr-namespace:System.Windows;assembly=System.Windows.Controls"
it is not a design-time error. i have close the xaml-file when i build the project.
but, i have this error when i open the xaml-file in the design-view.
the errormessage is: "Die Assembly "System.Windows.Controls" wurde nicht gefunden. Alle Assemblyverweise müssen vorhanden sein, und das Projekt sowie alle referenzierten Assemblys müssen erstellt worden sein."
i think, the error is about the assembly reference. but, i can't found an other.
JenniferNery
You must be using Silverlight code on WPF? Kindly see XMLNS on this page. http://msdn.microsoft.com/en-us/library/system.windows.controls.control.aspx
