jtc file
662
07-28-2011 01:54 AM
sagihadas
New Contributor III
We installed WMX on SDE10, we performed the post installation and everything works fine, but when we wanted to distribute the JTC file, we couldn't find it. There is no DATABASE folder in the WMX installation folder.
We need some help. Does anyone know where the JTC file is hiding?
hadas
BrianDemers
Hi Hadas,
The Database folder (and a few others) moved relatively recently, I think due to permissions changes on Windows Vista/7.  It's now typically found under "C:\ProgramData\ESRI\WMX" or "C:\Documents and Settings\All Users\Application Data\ESRI\WMX" (on XP).
If you don't find it in either of those places, try running the Workflow Manager Advanced Settings Tool to see how your system is configured.
I hope this helps...
Brian D.
sagihadas
New Contributor III
Thank you, we found it under "C:\ProgramData\ESRI\WMX" or "C:\Documents and Settings\All Users\Application Data\ESRI\WMX"
Hadas
