inverse cost barriers
355
07-27-2011 08:27 PM
LukePhilips
New Contributor III
Does anyone know if it is possible to set up polygon barriers such that they are a reward instead of to be avoided?
MichaelRice
New Contributor III
Yes, this can be done. There are two types of polygon barriers: restricted polygon barriers and scaled polygon barriers. When you create your polygon barrier, you can open its properties (right-click the barrier in the Network Analyst Window and click 'Properties...') and see its associated field values. Make sure the 'BarrierType' field value is set to 'Scaled Cost'. Then, assuming you are solving on cost attribute X, set the 'Attr_X' field value to some positive value less than 1 (e.g., 0.25). This field value sets the scale factor applied to cost attribute X for all underlying network elements covered by the polygon. Setting this value less than 1 effectively causes the solvers to "prefer" these areas more than they would have normally. You can adjust the scale factor depending on how much you wish to prefer these polygon areas.
