import arcpy import os import multiprocessing def worker(d): # buffer layer by the below values bfs = [101, 200, 201, 400, 401, 750, 751, 1001, 1500, 1501, 2000, 2001, 2500] for bf in bfs: Output = os.path.basename(d)[:-4] + "_Buffer" + str(bf) + ".shp" print "Buffering " + d + " at " + str(bf) + " Feet" if arcpy.Exists(d): arcpy.Buffer_analysis(d, "D:\\Temp\\" + Output, str(bf) + " Feet") arcpy.Project_management("D:\\Temp\\" + Output, "D:\\Temp\\Test\\" + Output, "C:\Program Files (x86)\ArcGIS\Desktop10.0\Coordinate Systems\Geographic Coordinate Systems\North America\NAD 1983.prj") arcpy.Delete_management("D:\\Temp\\" + Output) else: print "No Data" # if it worked, return sucess resultString = 'Layer complete: %s' % (d) return resultString if __name__ == '__main__': #Sets MXD mxd = arcpy.mapping.MapDocument("D:\TEMP\Untitled4.mxd") #mxd = arcpy.mapping.MapDocument("CURRENT") #set some environments needed to get the correct outputs arcpy.env.overwriteOutput = True arcpy.env.workspace = "D:\TEMP\Test" arcpy.env.outputCoordinateSystem = "C:\Program Files (x86)\ArcGIS\Desktop10.0\Coordinate Systems\Projected Coordinate Systems\UTM\NAD 1983\NAD 1983 UTM Zone 16N.prj" # of processors to use set for max minus 1 prc = int(os.environ["NUMBER_OF_PROCESSORS"]) - 1 # Create and start a pool of worker processes pool = multiprocessing.Pool(prc) # Gets all layer in the Current MXD lyrs = arcpy.mapping.ListLayers(mxd) # print info of number of processors, number of layers, and the layer list arcpy.AddMessage(str(prc)+' - '+str(len(lyrs))' - '+str(lyrs)) # start job server jobs = [] #Loops through every layer and gets source data name and path for lyr in lyrs: d = lyr.dataSource print "Passing " + d + " to processing pool" arcpy.AddMessage("Passing " + d + " to processing pool") # add worker to job server jobs.append(pool.apply_async(worker(d))) # get 'results' from each worker in job server for job in jobs: arcpy.AddMessage(job.get())
import arcpy import os import pp import time #forces script to run out of process no matter what import win32com.client gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1") def wrker(d,bf): #pp module everything in here get to run in multiprocesses #much faster than a single thread # DO NOT USE arcpy.AddMessage() OR arcpy.addError() IN THIS PART OF THE SCRIPT. #set enviroments for each pp process arcpy.env.overwriteOutput = True arcpy.env.workspace = "D:\TEMP\Test" arcpy.env.outputCoordinateSystem = "C:\Program Files (x86)\ArcGIS\Desktop10.0\Coordinate Systems\Projected Coordinate Systems\UTM\NAD 1983\NAD 1983 UTM Zone 16N.prj" # Buffer distance in Feet distance = str(bf) + " Feet" #output file will go into the Workspace from above Output = os.path.basename(d)[:-4] + "_Buffer" + str(bf) + ".shp" #no .shp at the end of an In_memory feature Tempfile = "In_memory\\" + Output[:-4] Jobdone = d + " buffered by " + distance Jobfail = d + " failed to buffer by " + distance if arcpy.Exists(d): arcpy.Buffer_analysis(d, Tempfile, distance) arcpy.Project_management(Tempfile, Output, "C:\Program Files (x86)\ArcGIS\Desktop10.0\Coordinate Systems\Geographic Coordinate Systems\North America\NAD 1983.prj") arcpy.Delete_management(Tempfile) #print "Buffering " + d + " at " + distance else: print Jobfail #deletes In_memory temp file as to not hold ram. del Tempfile #data retruned to main code and used in messaging there return Jobdone if __name__ == '__main__': #starts clock clck_st = time.clock() #Sets MXD can not use current for pp processing mxd = arcpy.mapping.MapDocument("D:\TEMP\Untitled4.mxd") #Gets all layer in the Current MXD lyrs = arcpy.mapping.ListLayers(mxd) #PP prep # of processors to use set for max minus 1 prc = int(os.environ["NUMBER_OF_PROCESSORS"]) - 1 #using Parellel python ppservers=() #sets workers to prc job_server = pp.Server(prc, ppservers=ppservers) #sets workers to the max available #job_server = pp.Server(ppservers=ppservers) print "Processing all Layers in the mxd" arcpy.AddMessage("Processing all Layers in the mxd") #list to hold all of the jobs jobs = [] #List of buffer values bfs = [101, 200, 201, 400, 401, 750, 751, 1001, 1500, 1501, 2000, 2001, 2500] #Loops through every layer and gets source data name and path for lyr in lyrs: d = lyr.dataSource arcpy.AddMessage("Passing " + d + " to processing pool") for bf in bfs: jobs.append(job_server.submit(wrker,(d,bf), (), ("arcpy","os","time"))) #wrker(d) msg = "Passing " + d + " buffer at " + str(bf) + " Feet to processing pool" print msg arcpy.AddMessage(msg) # Retrieve results of all submited jobs for job in jobs: print job() arcpy.AddMessage(job()) #script is finished print "Processing completed in " + str(int(time.clock() - clck_st)) + " seconds" arcpy.AddMessage("Processing completed in " + str(int(time.clock() - clck_st)) + " seconds") time.sleep(5)
I received Memory Error after the total footprint of all four processes had grown to about 4 GB
"ArcGIS will go to 64-bit GP environment (not the entire application just the Geoprocessing environment) I was told that at the ESRI UC 2011 by an ESRI employee"
