b.greenhill
Darinage points are not calaculated correctly
Discussion created by b.greenhill on Jul 26, 2011
I am having the problem that the drainage points are not calculated at the correct point whithin the depressions, i.e. not at the lowest point! I only figured out when checking the results with a contur map.
I am using version: 2.0.1.59.
So the fdr and fac are calculated wrong. I run "LevelDem" and "reconditioning", "burn rivers" and then "flow direction with sinks".
Does anybody know why ArcHydro does this?
Outcomes
