Distance analysis: points to rivers
294
07-25-2011 03:33 AM
NatalieSusmann1
Hi
I need to find out the shortest distance of points (archaeological sites) to a stream dataset I have. I am running ArcEditor 9.3. It doesn't matter if it requires a conversion to raster-- I am using the output to find the average distance between sites and streams in order to perform an area of likely settlement analysis. Which tool should I use?
MarkEllis
I recall spatial analyst having some functions that would do this - NEAREST or some such.  Output cells contain the linear distance from the cell to whatever feature is being analyzed. This could then give you the values at the points you seek.
DanLee
by Esri Regular Contributor
You can use the Near tool in Analysis toolbox - Proximity toolset. Hope you have an ArcInfo license.
Regards,
michaelcollins1
Occasional Contributor III
