nuisanceheather
If-then-else using Calculate Value in a Geoprocessing Service
Discussion created by nuisanceheather on Jul 22, 2011
Latest reply on Jul 25, 2011 by nuisanceheather
Hello all,
Could you please help me find out why and how to fix a Geoprocessing model (v10)? The current model calculates census data and needs to have an if-then-else using the Calculate Value tool. The code below is working wonderfully on desktop, but crashes in a service with the following error:
Error 000539: Error running expression: x(r"c:\arcgisserver\arcgisjobs\Population_tools\model3_gpserver\jb18558850e7e47799a\scratch\scratch.gdb\Census_join") <type 'exceptions.ImportError'>: No module named collections
Failed to execute
Python code within Calculate Value in Geoprocessing Service:
# First Calculate Value should count the number of rows in the feature class and continue with
# the calculations if it is = 1 row.
Expression:
x(r"%Census_join%")
Code Block:
def x(InputFeatureClass):
import arcpy
result = arcpy.GetCount_management(InputFeatureClass)
if int(result.getOutput(0)) == 1:
return "true"
else:
return "false"
# Second Calculate Value should count the number of rows in the feature class and continue with
# the calculations if there is > 1 row.
Expression:
x(r"%Census_join%")
Code Block:
import arcpy
return "false"
else:
return "true"
Data type: Boolean
Any help to make this work as a service...would be hugely helpful!
Thank you.
Outcomes
