swenwaschk
Trouble getting the legend to work
Discussion created by swenwaschk on Jul 21, 2011
Latest reply on Sep 10, 2011 by swenwaschk
I'm in a bit of a struggle here. I don't seem to be able to get the legend to work here. Maybe i'm overlooking something.
dojo.require("esri.map");
dojo.require("esri.dijit.Scalebar");
dojo.require("esri.dijit.OverviewMap");
dojo.require("esri.toolbars.draw");
dojo.require("esri.toolbars.edit");
dojo.require("esri.dijit.Legend");
    var layer, map, editToolbar, ctxMenuForGraphics, selected, visible = [];
    function init() {
  esriConfig.defaults.map.slider = {left : "23px", top : "65px", width : null, height : "200px"};
  esri.bundle.toolbars.draw.addPoint = "Klik om een punt toe te voegen";
  esri.bundle.toolbars.draw.start = "Klik om te beginnen met tekenen";
  esri.bundle.toolbars.draw.resume = "Klik om verder te tekenen";
  esri.bundle.toolbars.draw.complete = "Dubbelklik om te voltooien";
  esri.bundle.toolbars.draw.freehand = "Druk om te beginnen en laat los om te voltooien";
        var initExtent = new esri.geometry.Extent({"xmin":126966,"ymin":359066,"xmax":198909,"ymax":401108,"spatialReference":{"wkid":28992}});
        map = new esri.Map("map", {extent: initExtent , logo: false});
  //Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
        var basemap = new esri.layers.ArcGISDynamicMapServiceLayer("http://atlas.sre.nl/ArcGIS/rest/services/OpenStreetMapZW/MapServer");
        map.addLayer(basemap);
  //Add the layer for the layerlist
        layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://atlas.sre.nl/ArcGIS/rest/services/Gemeentegrenzen/MapServer");
        if (layer.loaded) {
          buildLayerList(layer);
        else {
          dojo.connect(layer, "onLoad", buildLayerList);
  dojo.connect(map,'onLayersAddResult',function(results){
         //add the legend
          var legend = new esri.dijit.Legend({
            map:map,
            layerInfos:[{layer:dynamicLayer,title:"Public Safety"}],
            arrangement:esri.dijit.Legend.ALIGN_RIGHT
          },"legendDiv");
          legend.startup();
  //resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in
        //the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_guidelines.htm
        var resizeTimer;
        dojo.connect(map, 'onLoad', function(theMap) {
          dojo.connect(dijit.byId('map'), 'resize', function() { //resize the map if the div is resized
            clearTimeout(resizeTimer);
            resizeTimer = setTimeout(function() {
              map.resize();
              map.reposition();
            }, 500);
   //add the overview map
   var overviewMapDijit = new esri.dijit.OverviewMap(
     map : map,
     attachTo : "bottom-right",
     color : "#769dc0",
     visible : true
   overviewMapDijit.startup();
  //add the scale bar
  var scalebar = new esri.dijit.Scalebar(
    map : map,
    scalebarUnit : 'metric'
  dojo.connect(map, "onLoad", createToolbarAndContextMenu)
  dojo.connect(map, "onLoad", createToolbar);
    function buildLayerList(layer) {
  var items = dojo.map(layer.layerInfos,function(info,index){
   if (info.defaultVisibility) {
    visible.push(info.id);
   return "<input type='checkbox' class='list_item' checked='" + (info.defaultVisibility ? "checked" : "") + "' id='" + info.id + "' onclick='updateLayerVisibility();' /><label for='" + info.id + "'>" + info.name + "</label><br>";
        dojo.byId("layer_list").innerHTML = items.join("");
        layer.setVisibleLayers(visible);
        map.addLayer(layer);
    function updateLayerVisibility() {
        var inputs = dojo.query(".list_item"), input;
        visible = [];
        dojo.forEach(inputs,function(input){
   if (input.checked) {
    visible.push(input.id);
  //if there aren't any layers visible set the array to be -1
   if(visible.length === 0){
    visible.push(-1);
 function createToolbarAndContextMenu(map) {
 // Create and setup editing tools
  editToolbar = new esri.toolbars.Edit(map);
  dojo.connect(map,"onClick", function(evt){
   editToolbar.deactivate();
   //navToolbar.deactivate();
  createMapMenu();
  createGraphicsMenu();
 function createMapMenu() {
 // Creates right-click context menu for map
  ctxMenuForMap = new dijit.Menu({
   onOpen: function(box) {
  /*ctxMenuForMap.addChild(new dijit.MenuItem({
   label: "Add Point",
   onClick: function addToMap (geometry) {
    map.showZoomSlider();
    var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,0,0.25]));
    var graphic = new esri.Graphic(geometry, symbol);
    map.graphics.add(graphic);
  ctxMenuForMap.startup();
  ctxMenuForMap.bindDomNode(map.container);
 function createGraphicsMenu() {
 // Creates right-click context menu for GRAPHICS
   ctxMenuForGraphics = new dijit.Menu({});
  ctxMenuForGraphics.addChild(new dijit.MenuItem({
   label: "bewerken",
   onClick: function() {
    if(selected.geometry.type !== "point"){
      editToolbar.activate(esri.toolbars.Edit.EDIT_VERTICES, selected);
    else{
      alert("Niet van toepassing");
   label: "verplaatsen",
    editToolbar.activate(esri.toolbars.Edit.MOVE, selected);
   label: "roteren/schaal",
     editToolbar.activate(esri.toolbars.Edit.ROTATE | esri.toolbars.Edit.SCALE, selected);
    else{
  /*ctxMenuForGraphics.addChild(new dijit.MenuItem({
   label: "Style",
    alert("Not implemented");
  ctxMenuForGraphics.addChild(new dijit.MenuSeparator());
   label: "verwijderen",
    map.graphics.remove(selected);
  ctxMenuForGraphics.startup();
  dojo.connect(map.graphics, "onMouseOver", function(evt) {
     // We'll use this "selected" graphic to enable editing tools
     // on this graphic when the user click on one of the tools
     // listed in the menu.
   selected = evt.graphic;
     // Let's bind to the graphic underneath the mouse cursor
   ctxMenuForGraphics.bindDomNode(evt.graphic.getDojoShape().getNode());
  dojo.connect(map.graphics, "onMouseOut", function(evt) {
   ctxMenuForGraphics.unBindDomNode(evt.graphic.getDojoShape().getNode());
 function createToolbar(themap) {
   resizeMap();
  toolbar = new esri.toolbars.Draw(map);
  dojo.connect(toolbar, "onDrawEnd", addToMap);
 function addToMap(geometry) {
  toolbar.deactivate();
   switch (geometry.type) {
    case "point":
       break;
    case "polyline":
       var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255,0,0]), 1);
       break;
    case "polygon":
       var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25]));
       break;
    case "extent":
       break;
dojo.addOnLoad(init);
Thanks in advance for all your help.
Outcomes
