I modified the find task with results in a grid to use an identify task:
<!doctype html">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Display Identify Task results in Dojo DataGrid</title>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dojox/grid/resources/Grid.css">
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dojox/grid/resources/claroGrid.css">
<script type="text/javascript">dojoConfig = { parseOnLoad:true }</script>
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
</style>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script>
dojo.require("esri.map");
dojo.require("dojox.grid.DataGrid");
dojo.require("dojo.data.ItemFileReadStore");
dojo.require("esri.tasks.identify");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.form.Button");
var idTask, idParams;
var map, startExtent;
var grid, store;
function init() {
dojo.connect(grid, "onRowClick", onRowClickHandler);
//Create map and add the ArcGIS Online imagery layer
startExtent = new esri.geometry.Extent({"xmin":-9275203,"ymin":5248350,"xmax":-9271966,"ymax":5249253,"spatialReference":{"wkid":102100}});
map = new esri.Map("map", { extent: startExtent});
var streetMapLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
map.addLayer(streetMapLayer);
// Dynamic map service used by the Identify task
// Uncomment the next two lines to see parcel boundaries
// var parcelLayer = new esri.layers.ArcGISDynamicMapServiceLayer('http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/TaxParcelQuery/MapServer');
// map.addLayer(parcelLayer);
//Create Identify Task using the URL of the map service to search
idTask = new esri.tasks.IdentifyTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/TaxParcelQuery/MapServer");
//Create the identify parameters
idParams = new esri.tasks.IdentifyParameters();
idParams.returnGeometry = true;
idParams.layerIds = [0];
idParams.tolerance = 3;
idParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
idParams.width = map.width;
idParams.height = map.height;
dojo.connect(map, 'onClick', doIdentify);
var resizeTimer;
dojo.connect(map, 'onLoad', function(theMap) {
dojo.connect(dijit.byId('map'), 'resize', function() { //resize the map if the div is resized
clearTimeout(resizeTimer);
resizeTimer = setTimeout( function() {
map.resize();
map.reposition();
}, 500);
function doIdentify(evt) {
//Set the search text to the value in the box
idParams.geometry = evt.mapPoint;
idParams.mapExtent = map.extent;
console.log('do ID: ', evt, '; params: ', idParams);
idTask.execute(idParams, showResults);
function showResults(results) {
console.log('got results: ', results);
map.graphics.clear();
var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 2), new dojo.Color([98,194,204,0.5]));
//create array of attributes
var items = dojo.map(results,function(result){
var graphic = result.feature;
graphic.setSymbol(symbol);
map.graphics.add(graphic);
return result.feature.attributes;
//Create data object to be used in store
var data = {
identifier: "PARCELID", //This field needs to have unique values
label: "PARCELID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
items: items
//Create data store and bind to grid.
store = new dojo.data.ItemFileReadStore({ data:data });
var grid = dijit.byId('grid');
grid.setStore(store);
//Zoom back to the initial map extent
map.setExtent(startExtent);
//Zoom to the parcel when the user clicks a row
function onRowClickHandler(evt){
var clickedTaxLotId = grid.getItem(evt.rowIndex).PARCELID;
var selectedTaxLot;
dojo.forEach(map.graphics.graphics,function(graphic){
if((graphic.attributes) && graphic.attributes.PARCELID === clickedTaxLotId){
selectedTaxLot = graphic;
return;
var taxLotExtent = selectedTaxLot.geometry.getExtent();
map.setExtent(taxLotExtent);
dojo.addOnLoad(init);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;">
<div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" style="height:40px;">
Identify Task + Dojo Data Grid
</div>
<div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit.layout.ContentPane" style="border:1px solid #000;"></div>
<div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'" style="height:150px;">
<table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
<thead>
<tr>
<th field="PARCELID">Parcel ID</th>
<th field="OWNERNME1" >Owner 1</th>
<th field="OWNERNME2">Owner 2</th>
<th field="RESYRBLT ">Year Built</th>
<th field="SITEADDRESS" width="100%">Address</th>
</tr>
</thead>
</table>
</div>
</div>
</body>
</html>
Two big changes: switch to an identify task and set up a map click handler; I didn't have to change any of the logic in the callback that handles the results from the identify task.
