Here's an example that shows using the PopupMobile with the PopupTemplate:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" />
<!--The viewport meta tag is used to improve the presentation and behavior of the
samples on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>
Flickr
</title>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css"/>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/esri/dijit/css/Popup.css"/>
<link rel="stylesheet" type='text/css' href='http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/esri/dijit/css/PopupMobile.css'/>
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; } .esriScalebar{
padding: 20px 20px; } #map{ padding:0;}
</style>
<script type="text/javascript">
var dojoConfig = {
parseOnLoad: true
</script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4">
</script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.layers.FeatureLayer");
dojo.require("esri.dijit.Popup");
dojo.require("esri.dijit.PopupMobile");
var map;
var featureLayer;
var resizeTimer;
function init() {
//setup the map's initial extent
var initExtent = new esri.geometry.Extent({"xmin":-16305479,"ymin":-635073,"xmax":5884495,"ymax":8307447,"spatialReference":{"wkid":102100}});
//create a popup to replace the map's info window
var popup = new esri.dijit.PopupMobile(null, dojo.create("div"));
map = new esri.Map("map", {
extent: initExtent,
infoWindow: popup
dojo.place(popup.domNode, map.root);
//Add the imagery layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer");
map.addLayer(basemap);
//create a feature collection for the flickr photos
var featureCollection = {
"layerDefinition": null,
"featureSet": {
"features": [],
"geometryType": "esriGeometryPoint"
featureCollection.layerDefinition = {
"geometryType": "esriGeometryPoint",
"objectIdField": "ObjectID",
"drawingInfo": {
"renderer": {
"type": "simple",
"symbol": {
"type": "esriPMS",
"url": "images/flickr.png",
"contentType": "image/png",
"width": 15,
"height": 15
"fields": [{
"name": "ObjectID",
"alias": "ObjectID",
"type": "esriFieldTypeOID"
"name": "description",
"alias": "Description",
"type": "esriFieldTypeString"
"name": "title",
"alias": "Title",
//define a popup template
var popupTemplate = new esri.dijit.PopupTemplate({
title: "{title}",
description:"{description}"
//create a feature layer based on the feature collection
featureLayer = new esri.layers.FeatureLayer(featureCollection, {
infoTemplate: popupTemplate
//associate the features with the popup on click
dojo.connect(featureLayer,"onClick",function(evt){
map.infoWindow.setFeatures([evt.graphic]);
map.infoWindow.show(evt.mapPoint);
dojo.connect(map,"onLayersAddResult",function(results){requestPhotos();});
//add the feature layer that contains the flickr photos to the map
map.addLayers([featureLayer]);
//resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in
//the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_guidelines.htm
dojo.connect(map, 'onLoad', function(theMap) {
dojo.connect(dijit.byId('map'), 'resize', function() { //resize the map if the div is resized
clearTimeout(resizeTimer);
resizeTimer = setTimeout(function() {
map.resize();
map.reposition();
}, 500);
function requestPhotos(){
//get geotagged photos from flickr
//tags=flower&tagmode=all
var requestHandle = esri.request({
url: "http://api.flickr.com/services/feeds/geo?&format=json",
callbackParamName: "jsoncallback",
load: requestSucceeded,
error: requestFailed
useProxy: false
function requestSucceeded(response, io) {
//loop through the items and add to the feature layer
var features = [];
dojo.forEach(response.items, function(item) {
var attr = {};
attr["description"] = item.description;
attr["title"] = item.title ? item.title : "Flickr Photo";
var geometry = esri.geometry.geographicToWebMercator(new esri.geometry.Point(item.longitude, item.latitude, map.spatialReference));
var graphic = new esri.Graphic(geometry);
graphic.setAttributes(attr);
features.push(graphic);
featureLayer.applyEdits(features, null, null);
function requestFailed(error) {
console.log('failed');
dojo.ready(init);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'"
style="width: 100%; height: 100%; margin: 0;">
<div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"
style="border:1px solid #000;padding:0;">
</div>
</div>
</body>
</html>
