DCSlatunn
generate kml
Discussion created by DCSlatunn on Jul 11, 2011
Latest reply on Jul 14, 2011 by DCSlatunn
Hi, I am trying to export a kml using the javascript REST api.  I see in the documentation that there is a "generateKml" operation (see: http://atlas.resources.ca.gov/ArcGIS/SDK/REST/mapserver.html) however it does not seem to be available.  I am getting an error: "generateKml is not a function".  If I look at it in firebug, I see available methods "exportMap" and "queryLayer", but no "generateKml". Does anyone know what I may be doing wrong?  We have the most current API downloaded.  How can I export a kml via the rest api?
EDIT:
I have the following working...kinda:  //myServer/ArcGIS/rest/services/myService/MapServer/generatekml?docName=Test+Name&layers=1,2&layerOptions=separateImage
This creates a KML with a big red X in the correct location in google earth.  So, it seems to be doing something right, just not displaying the image correctly.  If I use the URL above with "nonComposite" (vector) as a parameter, I get no image.
//myServer/ArcGIS/rest/services/myService/MapServer/kml/mapImage.kmz seems to work, but I need a vector representation instead of one large image.
So, I guess the question has changed to: how can I export a vector KML?  And/or how do I use "generateKml" ??
Outcomes
